The Fabric community is now in read-only for platform upgrade. Learn more
Problem with running PowerBI Desktop - CreateFile2 not found
Hello community! I am not sure I'm posting in the correct category as I only get "Suggest a new idea" in the "Issues" forum, feel free to move it
I have uninstalled and reinstalled PowerBI Desktop on my Windows 7 laptop (it's an enteprise Windows 7 so I can't update it), but I am having trouble running it again.
Whenever I run it, whether be 32 or 64bit, with or without admin privileges, I mostly get the following issues (I'll try to translate in English when possible)
> Entry point CreateFile32 was not found in the KERNEL32.dll dynamic library
And then I get the following stack trace , a big long so I'll leave it at the end.
Am I missing some Microsoft C++ library or anything? Is Windows 7 not working anymore?
Thanks for the help,
Fanilo
Stacktrace:
Feedback Type:
Frown (Error)
Error Message:
AS Process PID=13016 has exited with ExitCode=-1073741511, ExitTime=2021-03-22T15:41:41.7764009+01:00
Stack Trace:
Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcessUnexpectedExitException
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcess.AcquireServerDynamicPortInfo()
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcess.EnsureServiceIsReady()
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcess.Start()
à System.Threading.Tasks.Task.Execute()
--- Fin de la trace de la pile à partir de l'emplacement précédent au niveau duquel l'exception a été levée ---
à System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesService.<StartProcess>d__22.MoveNext()
à Microsoft.PowerBI.Client.Windows.Utilities.TaskExtensions.WaitAndUnpackException(Task task)
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesService.CreateEmptyDatabase()
à System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
à Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<HandleAwaitableAsyncExceptions>d__1.MoveNext()
Stack Trace Message:
Invocation Stack Trace:
à Microsoft.Mashup.Host.Document.ExceptionExtensions.GetCurrentInvocationStackTrace()
à Microsoft.Mashup.Client.UI.Shared.StackTraceInfo..ctor(String exceptionStackTrace, String invocationStackTrace, String exceptionMessage)
à Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.GetStackTraceInfo(Exception e)
à Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.ReportException(IWindowHandle activeWindow, IUIHost uiHost, FeedbackPackageInfo feedbackPackageInfo, Exception e, Boolean useGDICapture)
à Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.<>c__DisplayClass15_0.<HandleException>b__0()
à Microsoft.Mashup.Host.Document.SynchronizationContextExtensions.<>c__DisplayClass2_1.<SendAndMarshalExceptions>b__0(Object null)
à System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
à System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
à System.Delegate.DynamicInvokeImpl(Object[] args)
à System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
à System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
à System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
à System.Windows.Forms.Control.InvokeMarshaledCallbacks()
à System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
à System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
à System.Windows.Forms.WindowsFormsSynchronizationContext.Send(SendOrPostCallback d, Object state)
à Microsoft.Mashup.Host.Document.SynchronizationContextExtensions.SendAndMarshalExceptions(SynchronizationContext context, Action callback)
à Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.HandleException(Exception e)
à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Runtime.CompilerServices.AsyncMethodBuilderCore.MoveNextRunner.Run()
à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
à Microsoft.PowerBI.Client.Windows.Services.UIBlockingService.RefCount.RefCountScope.<Dispose>b__2_0()
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
à System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
à System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
à System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
à System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
à Microsoft.PowerBI.Client.Windows.Services.UIBlockingService.WaitOnUIThreadForTaskCompletion[T](Task`1 task)
à Microsoft.PowerBI.Client.Windows.Services.UIBlockingService.BlockUIAndRun[T](Func`1 asyncMethod)
à Microsoft.PowerBI.Client.Windows.Services.FileManager.OpenFile(IPowerBIWindowService windowService, IPbixFile fileToOpen, Nullable`1 entryPoint)
à Microsoft.PowerBI.Client.Program.TryOpenOrCreateReport(IUIHost uiHost, IPowerBIWindowService windowService, IFileManager fileManager, IFileHistoryManager fileHistoryManager, String filePath, FileType fileType, IFileInformationProtectionManager fileInformationProtectionManager)
à Microsoft.PowerBI.Client.Program.<>c__DisplayClass4_0.<Main>b__1()
à Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<>c__DisplayClass3_0.<HandleExceptionsWithNestedTasks>b__0()
à Microsoft.Mashup.Host.Document.ExceptionHandlerExtensions.HandleExceptions(IExceptionHandler exceptionHandler, Action action)
à Microsoft.PowerBI.Client.Program.Main(String[] args)
PowerBINonFatalError:
{"AppName":"PBIDesktop","AppVersion":"2.91.701.0","ModuleName":"Microsoft.PowerBI.Client.Windows.dll","Component":"Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcess","Error":"Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcessUnexpectedExitException","MethodDef":"AcquireServerDynamicPortInfo","ErrorOffset":"110"}
PowerBIUserFeedbackServices_IsReported:
True
Status: New
Comments
v-lili6-msft
hi
Minimum requirements
The following list provides the minimum requirements to run Power BI Desktop:
 Important
Since January 31st 2021, Power BI Desktop is no longer supported on Windows 7.
  • Windows 8.1 / Windows Server 2012 R2, or later
  • .NET 4.6.2 or later
  • Internet Explorer 11 or later
  • Memory (RAM): At least 2 GB available, 4 GB or more recommended.
  • Display: At least 1440x900 or 1600x900 (16:9) required. Lower resolutions such as 1024x768 or 1280x800 aren't supported, as certain controls (such as closing the startup screen) display beyond those resolutions.
  • Windows display settings: If you set your display settings to change the size of text, apps, and other items to more than 100%, you may not be able to see certain dialogs that you must interact with to continue using Power BI Desktop. If you encounter this issue, check your display settings in Windows by going to Settings > System > Display, and use the slider to return display settings to 100%.
  • CPU: 1 gigahertz (GHz) 64-bit (x64) processor or better recommended.
https://docs.microsoft.com/en-us/power-bi/fundamentals/desktop-get-the-desktop#minimum-requirements
Lin
andfanilo
Hello @v-lili6-msft, thanks for your quick response, I missed this new requirement 😉
Have a good day,
Fanilo
Hi
Does this means , anyone can not learn in win7 (personal laptop). but in prerequisites its showing win7 is ok.
atillanzadeh
Hi, thanks sharing this problem. Can you do it? Did you use Power BI in windows 7. I have same problem. What can I do?
