Hello community! I am not sure I'm posting in the correct category as I only get "Suggest a new idea" in the "Issues" forum, feel free to move it
I have uninstalled and reinstalled PowerBI Desktop on my Windows 7 laptop (it's an enteprise Windows 7 so I can't update it), but I am having trouble running it again.
Whenever I run it, whether be 32 or 64bit, with or without admin privileges, I mostly get the following issues (I'll try to translate in English when possible)
> Entry point CreateFile32 was not found in the KERNEL32.dll dynamic library
And then I get the following stack trace , a big long so I'll leave it at the end.
Am I missing some Microsoft C++ library or anything? Is Windows 7 not working anymore?
Thanks for the help,
Fanilo
Stacktrace:
Feedback Type:
Frown (Error)
Error Message:
AS Process PID=13016 has exited with ExitCode=-1073741511, ExitTime=2021-03-22T15:41:41.7764009+01:00
Stack Trace:
Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcessUnexpectedExitException
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcess.AcquireServerDynamicPortInfo()
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcess.EnsureServiceIsReady()
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcess.Start()
à System.Threading.Tasks.Task.Execute()
--- Fin de la trace de la pile à partir de l'emplacement précédent au niveau duquel l'exception a été levée ---
à System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesService.<StartProcess>d__22.MoveNext()
à Microsoft.PowerBI.Client.Windows.Utilities.TaskExtensions.WaitAndUnpackException(Task task)
à Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesService.CreateEmptyDatabase()
à System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
à Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<HandleAwaitableAsyncExceptions>d__1.MoveNext()
Stack Trace Message:
Invocation Stack Trace:
à Microsoft.Mashup.Host.Document.ExceptionExtensions.GetCurrentInvocationStackTrace()
à Microsoft.Mashup.Client.UI.Shared.StackTraceInfo..ctor(String exceptionStackTrace, String invocationStackTrace, String exceptionMessage)
à Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.GetStackTraceInfo(Exception e)
à Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.ReportException(IWindowHandle activeWindow, IUIHost uiHost, FeedbackPackageInfo feedbackPackageInfo, Exception e, Boolean useGDICapture)
à Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.<>c__DisplayClass15_0.<HandleException>b__0()
à Microsoft.Mashup.Host.Document.SynchronizationContextExtensions.<>c__DisplayClass2_1.<SendAndMarshalExceptions>b__0(Object null)
à System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
à System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
à System.Delegate.DynamicInvokeImpl(Object[] args)
à System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
à System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
à System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
à System.Windows.Forms.Control.InvokeMarshaledCallbacks()
à System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
à System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
à System.Windows.Forms.WindowsFormsSynchronizationContext.Send(SendOrPostCallback d, Object state)
à Microsoft.Mashup.Host.Document.SynchronizationContextExtensions.SendAndMarshalExceptions(SynchronizationContext context, Action callback)
à Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.HandleException(Exception e)
à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Runtime.CompilerServices.AsyncMethodBuilderCore.MoveNextRunner.Run()
à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
à Microsoft.PowerBI.Client.Windows.Services.UIBlockingService.RefCount.RefCountScope.<Dispose>b__2_0()
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
à System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
à System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
à System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
à System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
à Microsoft.PowerBI.Client.Windows.Services.UIBlockingService.WaitOnUIThreadForTaskCompletion[T](Task`1 task)
à Microsoft.PowerBI.Client.Windows.Services.UIBlockingService.BlockUIAndRun[T](Func`1 asyncMethod)
à Microsoft.PowerBI.Client.Windows.Services.FileManager.OpenFile(IPowerBIWindowService windowService, IPbixFile fileToOpen, Nullable`1 entryPoint)
à Microsoft.PowerBI.Client.Program.TryOpenOrCreateReport(IUIHost uiHost, IPowerBIWindowService windowService, IFileManager fileManager, IFileHistoryManager fileHistoryManager, String filePath, FileType fileType, IFileInformationProtectionManager fileInformationProtectionManager)
à Microsoft.PowerBI.Client.Program.<>c__DisplayClass4_0.<Main>b__1()
à Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<>c__DisplayClass3_0.<HandleExceptionsWithNestedTasks>b__0()
à Microsoft.Mashup.Host.Document.ExceptionHandlerExtensions.HandleExceptions(IExceptionHandler exceptionHandler, Action action)
à Microsoft.PowerBI.Client.Program.Main(String[] args)
PowerBINonFatalError:
{"AppName":"PBIDesktop","AppVersion":"2.91.701.0","ModuleName":"Microsoft.PowerBI.Client.Windows.dll","Component":"Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcess","Error":"Microsoft.PowerBI.Client.Windows.AnalysisServices.AnalysisServicesProcessUnexpectedExitException","MethodDef":"AcquireServerDynamicPortInfo","ErrorOffset":"110"}
PowerBIUserFeedbackServices_IsReported:
True
