Hello Comunity
I need some help, Power Bi does not launch, this problem start one week ago, I re-install de app, but the problem persists.
any suggestion, idea, or trick, happens with all my clients in the company with Power bi Desktop.
Thank you all for the help
have a nice day...
here is the track
Feedback Type:
Frown (Error)
Error Message:
WebView2 Process Failed: DataExploreView, Source:https://ms-pbi.pbi.microsoft.com/pbi/Web/Views/HtmlControls/DataExploreView/DataExplore.htm ExitCode:-1073740760 Reason:Unexpected ProcessFailedKind:RenderProcessExited ProcessDescription:
Stack Trace:
Microsoft.PowerBI.Client.Windows.WebView2.WebView2ProcessCrashException
en Microsoft.PowerBI.Client.Windows.WebView2.WebView2BrowserWrapper.OnWebViewProcessFailed(Object sender, CoreWebView2ProcessFailedEventArgs args)
Stack Trace Message:
Invocation Stack Trace:
en Microsoft.Mashup.Host.Document.ExceptionExtensions.GetCurrentInvocationStackTrace()
en Microsoft.Mashup.Client.UI.Shared.StackTraceInfo..ctor(String exceptionStackTrace, String invocationStackTrace, String exceptionMessage)
en Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.GetStackTraceInfo(Exception e)
en Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.ReportException(IWindowHandle activeWindow, IUIHost uiHost, FeedbackPackageInfo feedbackPackageInfo, Exception e, Boolean useGDICapture)
en Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.<>c__DisplayClass15_0.<HandleException>b__0()
en Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.HandleException(Exception e)
en Microsoft.PowerBI.Client.Windows.Utilities.UIBlockingAwareExceptionHandler.HandleException(Exception e)
en Microsoft.PowerBI.Client.Windows.MainWindow.Microsoft.PowerBI.Client.Windows.ICefBrowserHost.OnFatalError(Exception e, String knownErrorMessage, String knownErrorDetailsUrl)
en System.EventHandler`1.Invoke(Object sender, TEventArgs e)
en System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
en System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
en System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
en System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
en System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
en Microsoft.Mashup.Client.UI.Windows.DialogWindowBase.ShowModal(IWindowHandle windowHandle)
en Microsoft.Mashup.Client.UI.Shared.WebDialogs.WebDialog.<>n__0(IWindowHandle owner)
en Microsoft.Mashup.Client.UI.Shared.WindowManager.ShowModal[T](T dialog, Func`1 showModalFunction)
en Microsoft.PowerBI.Client.Windows.MainForm.SetCefHost(ICefBrowserHost cefHost)
en Microsoft.PowerBI.Client.Windows.MainWindow..ctor(IPowerBIWindowServiceFactory windowServiceFactory, IEventAggregationService eventAggregationService, IFileOperationUIHandler fileOperationUIHandler, IFileManager fileManager, IFileMenuServicesProvider fileMenuServiceProvider, IQueryServicesProvider queryServicesProvider, IClientServicesProvider clientServicesProvider, IModelAuthoringRoutingService modelAuthoringRoutingService, IUIBlockingService uiBlockingService, IViewSelectionService viewSelectionService, IUpdateNotificationManager updateNotificationManager, IPowerBIStringProvider stringProvider, IPowerBITelemetryService telemetryService, ITypeNameProvider typeNameProvider, IUIHost uiHost, MainWindowParameters initializationParameters, FormulaHistoryManager formulaHistoryManager, IReportManager reportManager, IPowerBIServiceClient powerBIServiceClient, IAuthenticationManager authenticationManager, IAuthenticationUIHandler authenticationUIHandler, ICloudConfigurationManager cloudManager, ApplicationTracingHost applicationTracingHost, IFileHistoryManager fileHistoryManager, IBrowserFactory browserFactory, IPowerBISettings powerBISettings, IPowerBIConstants powerBIConstants, IAnalysisServicesLoadContextFactory analysisServicesLoadContextFactory, IApplicationCommands applicationCommands, IUISettings uiSettings, IFeatureSwitchManager featureSwitchManager, IFileDialogManager fileDialogManager, MainForm mainForm, ISystemEnvironment systemEnvironment)
en Microsoft.PowerBI.Client.Program.<>c__DisplayClass4_1.<Main>b__2()
en Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<>c__DisplayClass3_0.<HandleExceptionsWithNestedTasks>b__0()
en Microsoft.Mashup.Host.Document.ExceptionHandlerExtensions.HandleExceptions(IExceptionHandler exceptionHandler, Action action)
en Microsoft.PowerBI.Client.Program.Main(String[] args)
Browser Name:
DataExploreView
Browser Source:
Browser ExitCode:
-1073740760
Browser Crash Reason:
Unexpected
Browser Crash Kind:
RenderProcessExited
Browser Process Description:
PowerBINonFatalError:
{"AppName":"PBIDesktop","AppVersion":"2.100.684.0","ModuleName":"Microsoft.PowerBI.Client.Windows.dll","Component":"Microsoft.PowerBI.Client.Windows.WebView2.WebView2BrowserWrapper","Error":"Microsoft.PowerBI.Client.Windows.WebView2.WebView2ProcessCrashException - WebView2 Process Failed: DataExploreView, Source:https://ms-pbi.pbi.microsoft.com/pbi/Web/Views/HtmlControls/DataExploreView/DataExplore.htm ExitCode:-1073740760 Reason:Unexpected ProcessFailedKind:RenderProcessExited ProcessDescription:","MethodDef":"OnWebViewProcessFailed","ErrorOffset":"125"}
Model Default Mode:
Empty
Model Version:
PowerBI_V1
Enabled Preview Features:
PBI_enableWebView2
PBI_sparklines
Disabled Preview Features:
PBI_shapeMapVisualEnabled
PBI_SpanishLinguisticsEnabled
PBI_qnaLiveConnect
PBI_azureMapVisual
PBI_dataPointLassoSelect
PBI_compositeModelsOverAS
PBI_dynamicParameters
PBI_enhancedTooltips
PQ_WebView2Connector
PBI_useModernFormatPane
PBI_scorecardVisual
Disabled DirectQuery Options:
TreatHanaAsRelationalSource
Cloud:
GlobalCloud
PowerBINonFatalError_ErrorDescription:
PowerBIUserFeedbackServices_IsReported:
True
Formulas:
section Section1;
Similar issue has reported internally(Existing ICM:279388210).
