Hi, I'm facing an issue on trying to connect Power BI to Azure SQL Server with Private endpoint activate and public access disable.
After creating an virtual network gateway on Power Platform I could access Azure SQL Server on Power BI DataFlow creation with no issues. However, after saving data flow creation and confim first execution, system displayed "Execution for On-Prem data source failed because it's not registered on a gateway (218884)" message.
Could someone help me to identify the solution for that issue?
Hi @marcosdp,
If you directly register your Azure SQL data source to your VNet gateway, will you see any error? Please create and save your dataflow after you register successfully there.
Community Support Team _ Caiyun
