marcosdp
4 years agoRegular Visitor
Status:
Investigating
Issues on connection between Power BI and Azure SQL Database using VNet service endpoints
Hi, I'm facing an issue on trying to connect Power BI to Azure SQL Server with Private endpoint activate and public access disable. After creating an virtual network gateway on Power Platform I coul...
v-cazheng-msft
4 years agoStatus changed:
New
to Investigating
Hi marcosdp,
If you directly register your Azure SQL data source to your VNet gateway, will you see any error? Please create and save your dataflow after you register successfully there.
Community Support Team _ Caiyun
