Open Side Menu
Skip to contentBrand Logo
Forums
Inspiration
Ideas
Communities
Blogs
Learning
Support
RegisterSign In
  1. Microsoft Fabric Community
  2. Power BI forums
  3. Issues
  4. Issues
marcosdp's avatar
marcosdp
4 years ago
Status:
Investigating
Issues on connection between Power BI and Azure SQL Database using VNet service endpoints
Hi, I'm facing an issue on trying to connect Power BI to Azure SQL Server with Private endpoint activate and public access disable. After creating an virtual network gateway on Power Platform I coul...
Gateways
aksmith's avatar
aksmith
3 years ago
We are having the same issue also - anyone know if there is a fix?
Completed Ideas
  • Set as landing page feature missing in Apr 2026 update (Build 2.153.1206.0) both in Desktop and Serv
  • Input Slicer Bug: Cursor jumps to position 0 and values cannot be cleared in Service
  • Input Slicer Causing Browser Tab Freeze in Public Links (Started April 24, 2026)
  • Small multiples not fitting to scale
  • Previously working Mac calender visual now gives me a error every time I touch it!
  • Text Slicer does not reset via Bookmarks or Clear All in Power BI Service (Service-only behavior)
  • Text Input Slicer is not reset by bookmarks in Power BI Service while working correctly in Power BI
  • Azure maps not displaying mapped data points in publish to web when location used
  • Azure Maps reference layer transparency behaves differently after publishing to Power BI Service
  • Desktop Application Bug?? - PBI desktop application left navigation icons always solid black
  • © 2026 Microsoft
  • Manage cookies
  • Privacy & cookies
  • Terms of use
  • Trademarks
Your Privacy Choices Consumer Health Privacy
