0
Installation Problem for Power BI and SQL
Hi there,
Hope this message finds you well.
When I tried to install Power BI desktop and SQL Server 2019 Express version recently, they always failed with the notification of
"Could not open key: UNKNOWN\Components\..... Verify that you have sufficient access to that key, or contact your support personnel" with screenshots below for your reference.
Could you please advice what I could do next to install the two applications?
Appreciate your help in advance. Thank you.
Status: Done
Comments
v-yingjl
Hi @Doris_ji ,
You need to make updates to the permissions in the registry to allow the current use to install.
Please refer these below threads:
  1. Error 1402. Could not open key UNKNOWN\Components\.... Verify that you have sufficient access to tha...
  2. Error 1402. Could not open key, when installing RequisitePro
Note:
Before making any modifications to the Microsoft Registry Editor, it is strongly recommended that you make a backup of the existing registry.
v-yingjl
Status changed to: Done
