Register nowThe Fabric community is now in read-only for platform upgrade. Learn more
Hi there,
Hope this message finds you well.
When I tried to install Power BI desktop and SQL Server 2019 Express version recently, they always failed with the notification of
"Could not open key: UNKNOWN\Components\..... Verify that you have sufficient access to that key, or contact your support personnel" with screenshots below for your reference.
Could you please advice what I could do next to install the two applications?
Appreciate your help in advance. Thank you.
