The ultimate Microsoft Fabric, Power BI, Azure AI, and SQL learning event: Join us in Stockholm, September 24-27, 2024.
Save €200 with code MSCUST on top of early bird pricing!
Find everything you need to get certified on Fabric—skills challenges, live sessions, exam prep, role guidance, and more. Get started
Hi there
I've been having a strange problem with a dashboard for a few days now (maybe after the last update, but I'm not 100% sure).
Basically, when using the dashboard on Power Bi Desktop, I can click on a view and all the others are filtered as expected, considering that I have cross-filtering enabled instead of cross-highlighting.
On Power Bi Service, the same activity works for less than half a second and then the view returns to its original state, so the cross-filtering is not applied at all. This happens with every visualisation I can use as a filter. It certainly didn't happen two weeks ago.
I made another copy, duplicated the page, but got no results. There is no RLS or data source authorisation that would have an effect.
Any ideas? Is there anything I could have done wrong that would produce this result?
Thanks.
F
Hi @Frankie_Vannini ,
Would you mind providing the detailed version information? The version information will be different depending on the download channel.
Please make sure you are using the version downloaded from the official website and not the MS app store.
Also, what type of viusal is this issue occurring in? Thank you for the additional information so that we can better reproduce the issue!
Best regards.
Community Support Team_Caitlyn
