Hi there
I've been having a strange problem with a dashboard for a few days now (maybe after the last update, but I'm not 100% sure).
Basically, when using the dashboard on Power Bi Desktop, I can click on a view and all the others are filtered as expected, considering that I have cross-filtering enabled instead of cross-highlighting.
On Power Bi Service, the same activity works for less than half a second and then the view returns to its original state, so the cross-filtering is not applied at all. This happens with every visualisation I can use as a filter. It certainly didn't happen two weeks ago.
I made another copy, duplicated the page, but got no results. There is no RLS or data source authorisation that would have an effect.
Any ideas? Is there anything I could have done wrong that would produce this result?
Thanks.
F
