Fabric is Generally Available. Browse Fabric Presentations. Work towards your Fabric certification with the Cloud Skills Challenge.
I have a pie chart visual in my report that uses a calculated column as one of the fields. Up until now it stopped working in Power BI service. Nothing has changed on the report and it has always worked in the past. The visual works fine in Power BI desktop but when published to Service it gives me an error. Any ideas why it would stop working suddenly?
Hi @chang_B
It’s a known issue . The engineers are actively working on this issue and I will come back with an update if there is any progress.
