We have a report with drill through enabled from matrix cells : https://msit.powerbi.com/groups/6ffc50ad-e19a-4e3d-ad2d-488ffefedfec/reports/045b7ec5-c7c8-47ae-bba8... . It is working fine until this morning. The right click menu is not pop up any more. Failed on both edge and chrome. The report is working fine on local desktop. Also tried to republish the report still has the same issue. Please help to check what could be wrong.
-Yan
