0
Problems with dates when using R Script in Power Query
When I pass a dataframe to R from Power Query I run into a problem with dates. For instance if I pass a dataframe that represents a Date table to R using the following script:
    new_dataset <- dataset
The date field is returned as follows:
My goal was to pass a Date table to R and add some attributes to the Date table using R. But when I pass a Date table to R the dates are replaced with "Microsoft.OleDB.Date". Any idea what's causing this problem? What are the known issues with the R integration in Power Query?
Status: Done
Comments
v-haibl-msft
@MrDataGeek
I can repro the same issue as you. I’ve reported this issue to Power BI team: CRI 26879691.
I’ll post here once I get any update about it.
Herbert
Vicky_Song
Impactful Individual
Status changed to: Accepted
v-haibl-msft
@MrDataGeek
This is a known limitation that is not going to be fixed any time soon. The workaround is to convert the date time to a primitive type (e.g. string) before sending it to into R and then convert it back in resulting table.
Herbert
Vicky_Song
Status changed to: Done
Shivendra
Advocate II
I am having the same problem but Herbert's tick is worked for me now
thanks!!!
