Power BI generates ERROR after running R Script
I'm getting an error when I try to "Run R script". I'm using R 4.3.1 and I have R Studio installed.
I've uninstalled and installed the software a few times, and I've looked into the Options settings and even the program files for the R software. But, I still get errors no matter what I do. Perhaps I cannot use R (Version: 4.3.1) with Power BI (Version: 2.121.903.0 64-bit (September 2023).
Please advise.
Options SettingsOptions SettingsError message after running R ScriptError message after running R Script
Status: Needs Info
Comments
Hi @Idana
Looking at the error it seems that access to Rscript is denied, is it possible that access to the folder is restricted? Have you used R script on Desktop before?
