Get registeredGet Fabric Certified for FREE during Fabric Data Days. Don't miss your chance! Learn more
 on
		04-20-2022
		07:47 AM
			 on
		04-20-2022
		07:47 AM
Having downloaded the latest version of Power BI desktop (Version: 2.104.702.0 64-bit (April 2022)), we are now encountering an "A cyclic reference was encountered during evaluation" exception when refreshing the data from a MySQL database:
We've traced the issue to the use of a Parameter named `Schema` in the Power Query as follows:
    Source = MySQL.Database(Server, Database, [ReturnSingleDatabase=true]),
    <query name> = Source{[Schema=Schema,Item="<table name>"]}[Data]
    <query name>
A refresh of the data preview in the Power Query Editor works without any issues, it is only when we attempt to reload the data in the Power BI report that the exception is generated.
The issue is with the following specific snippet in the query:
Schema=Schema
The solution / workaround is to rename the Parameter to something other than "Schema". For example, the reload works as it did before if we change the query to use a new Parameter called "SourceSchema":
    <query name> = Source{[Schema=SourceSchema,Item="<table name>"]}[Data]
    <query name>
Whilst the use of a Parameter name which collides with a Power Query attribute name isn't a good principal to adopt, the concern is that this code has been working for months and is only generating an exception with the new version of Power BI Desktop.
The concern is that other users may have adopted this convention in their own Power BI reports and will therefore encoutner the same issue where:
 mattlee
					on:
					Error:Visuals display blank when export report to ...
			mattlee
					on:
				 on:
					New Button Slicer: Issue with the Grid type of Arr...
					on:
				 mattlee
					on:
					List Slicer Button Dimensions Ignored in Service
			mattlee
					on:
				 on:
					BUG: report connected to deleted semantic model ca...
					on:
				 on:
					Deployment pipelines don't support M365 groups
					on:
				 Hongju_Jung
					on:
					A Typo about Measure tools (Korean)
			Hongju_Jung
					on:
