Calculated column works in Power BI desktop but not Power BI service. Visual won't load.
I have a pie chart visual in my report that uses a calculated column as one of the fields. Up until now it stopped working in Power BI service. Nothing has changed on the report and it has always worked in the past. The visual works fine in Power BI desktop but when published to Service it gives me an error. Any ideas why it would stop working suddenly?
Status: Accepted
Comments
blopez11
It is still not working for me.
blopez11
The issue now seems to be resolved for us.
Maieev
Resolver I
Issue resolved for me too :).
ChinChin
I am having the same issue where any visuals using calculated columns won't have data on after the dataset is refreshed in the Power BI service. I have updated my Power BI Desktop to the May 2023 version and the issue still remains. Replacing the calculated columns with calculated measures have fixed the issue but there is a couple of the calculated columns that cannot be replaced with calculated measures. Why is this becoming an issue since Feb 2023?
akbar-amini-219
I had a similar problem, when I filtered my report with a slicer, in powerBI it worked, but in shared report it didn't.
Finally I changed my formula. I had "All" function and I changed it to "Allexcept"; and it worked.
I use cumulative measures in several reports. They show correctly in visualization in PBI desktop, but  in the service they show incorrect results. It worked correctly before.
As "ibendlin" informed me: " So yes, it is possible that there are differences in the rendering engine between desktop and service (we had very frequent service updates already this year). "
Will that issue be addressed some time soon?
Thank you!
Tempest_87
I had the exact same sounding problem. The below worked for me. Link here: https://community.fabric.microsoft.com/t5/Issues/Error-in-calculated-column-only-in-power-bi-service...
Credit to user magicbiman:
"I had the same issue, but I've worked out what was causing it in my case. One of my data sources, which the calculated column was referencing, didn't have it's privacy level appropriately defined in keeping with the other sources of data. This didn't prevent the desktop version from working, but when published to Power BI  service it was preventing the data from being retrieved.
You can check this from the Home bar -> data source settings -> select your referenced data source -> edit permissions. In my case the privacy level for the referenced data source hadn't been defined. Defining it appropriately resolved the issue."
PJHos
Advocate I
I am not sure if the OP solved their issue. I had the same issue where my calculated columns were not working. When I checked the semantic model I noticed that one of my TRUE FALSE columns was text and the value was -1 hence the errors. Converting this column to TRUE FALSE in desktop and republishing solved the issue. If you have the error check the semantic model tables to see if the data types are being correctly identified
