Renaming columns in Power Query doesn't show up in Power Bi desktop model/data/report view
When renaming columns in the power query editor (Table.RenameColumns) the steps are applied correctly.
When clicking close and apply the table is refreshed and the old column names are there. Renaming doesn't get through.
Power Bi reports refreshed on the Power Bi service don't have this problem. This problem first appeared Friday the 16th.
We use the Dataverse connector to connect to dynamics.
Status: Accepted
Hi @JS-PBI ,
The issue has been reported internally, if there're any progress, I will update here.
Best regards,
Community Support Team_yanjiang
Comments
AVESTO
Hi @v-yanjiang-msft
As per @NBurnat comment above, I too am experiencing the exact same issue.
Version: 2.123.742.0 64-bit (November 2023)
See below very basic querry which:
  • connects to Dataverse 'Source' CommonDataService.Database("orga12a3b4c.crm6.dynamics.com")
  • 'Navigates' to data Source{[Schema="dbo",Item="vf_mytableofdata"]}[Data]
  • 'Removes Columns' - standard Table.RemoveColumns script
  • 'Renames Columns' - standard Table.RenameColumns script (see below)
However query editor is closed and data is loaded... the Rename Columns doesn't hold
If i put the Table.RenameColumns step AHEAD of the Table.RemoveColumns Step... no difference. The Table.RemoveColumns step still executes and the un-wanted columns removed, but the Table.RenameColumns step does not hold.
SlackDave
This quite big bug has been reintroduced with either the Nov or Dec update. The August update download seems to be the only working version on this currently
Previous monthly updates to Power BI Desktop and the Power BI service - Power BI | Microsoft Learn
Anne-MarijnV
having the same issue with a dataverse table right now
EAD
Just noticed thie issue today and it is affecting old and new Datasets and Reports.
Everything was working fin until last month, not sure what changed
Now the renaming step from the Query Editor is ignored
All my reports are displaying errors becuase they column names on the Data model are different
Data sets change
Power Automate stopped working because the columns no longer exist😠
This is a great deal of time and effort to manully adjust column names!
