Feedback Type:
Frown (Error)
Timestamp:
2024-09-25T16:23:47.4306309Z
Local Time:
2024-09-25T10:23:47.4306309-06:00
Session ID:
9c212907-daeb-4f9f-8779-84544f3c1729
Release:
August 2024
Product Version:
2.135.7627.0 (24.08) (x64)
Stack Trace:
System.IO.FileLoadException
en Microsoft.PowerBI.ExploreHost.ExploreClient..ctor(IPowerViewHandler powerViewHandler, IFeatureSwitchesProxy featureSwitchesProxy, IDataShapeEngine dataShapeEngine, IQueryCancellationManager cancelManager)
en Microsoft.PowerBI.Client.Program.<>c__DisplayClass7_0.<RunApplicationLegacy>b__0()
en Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<>c__DisplayClass3_0.<HandleExceptionsWithNestedTasks>b__0()
en Microsoft.Mashup.Host.Document.ExceptionHandlerExtensions.HandleExceptions(IExceptionHandler exceptionHandler, Action action)
PowerBINonFatalError:
{"AppName":"PBIDesktop","AppVersion":"2.135.7627.0","ModuleName":"Microsoft.Powerbi.ExploreHost.dll","Component":"Microsoft.PowerBI.ExploreHost.ExploreClient","Error":"System.IO.FileLoadException","MethodDef":".ctor","ErrorOffset":"-1","ErrorCode":""}
OS Version:
Microsoft Windows NT 10.0.22631.0 (x64 es-MX)
CLR Version:
4.8 or later [Release Number = 533320]
Peak Virtual Memory:
37.3 GB
Private Memory:
104 MB
Peak Working Set:
179 MB
IE Version:
11.1.22621.0
User ID:
e959ece7-f797-432e-b5c2-68f268a32ac3
Workbook Package Info:
None
Telemetry Enabled:
True
DPI Scale:
100%
Supported Services:
Power BI
