Another ArgGIS question: Can anyone tell me why in some instances I can see the Drive Time icon when using the ArcGIS Editor and other times it is not present?
I have included two images below. The first shows the Editor without the Drive Time icon, while the second shows it with the icon.
When Drive Time icon is present, the Data Fields for the visual contains a Tooltips field. This field is ommit when the incon is missing.
I tried deleitng the cache from %localappdata%\Local\Microsoft\Power BI Desktop\CEF and the issue persisted. However, I deactivated the preview feature (File > Options and Settings > Options > Preview Features > Uncheck ArcGIS Maps for Power BI), restarted Power BI Desktop and activated it back again and now is working.
I'm using the Power BI Desktop 2.46.4732.581 64-bit (May 2017) version.
I am also getting the "Failed to locate Features" message when I know all the lat/longs are valid. I created a calculated field and rounded the lat longs to 2 decimal places which did find some of the missing items but not all.
