Esri Arcgis Maps does not load on Power BI Desktop for some files
For some reason, on some of my pbix files, the esri arcgis files will not load. I just get the loading screen below
Status: Accepted
Comments
deldersveld
Resident Rockstar
Are you able to share a PBIX that where the map does not load, or one of your datasets?
iokoli
@deldersveld, I am unable to share the pbix file as it contains information related to work.
v-qiuyu-msft
Hi @iokoli,
Which desktop version did you run? How about running the latest desktop version 2.43.4647.541?
Qiuyun Yu
Vicky_Song
Impactful Individual
Status changed to: Needs Info
iokoli
@v-qiuyu-msft I am running the latest Desktop Version of Power BI
iokoli
Just for some addedd information, when i start a new Power BI file and create a new esri map. Then I change tabs and  go back to the map, the map does not load.
I have also tried reinstalling Power BI with no success.
Please let me know if you need any further information.
iokoli
 @Vicky_Song What happens now that this is designated as "Needs Info"?
v-qiuyu-msft
Hi @iokoli,
Which language version of desktop did you run? Check if this .pbix can load ArcGis map on your side: https://www.dropbox.com/s/mza7hql40lufq17/ARCGis%20Maps.pbix?dl=0
Qiuyun Yu
edwardkench
Having the same problem with one workstation. Only get the 3 yellow status bars and "esri" in the background. I updated to latest, uninstalled and reinstalled today, no change. This workstation has been used to build several esri maps in the past without issues.
Also I tried the file out on Dropbox by Qiuyun Yu with the same results. No map.
thekevinj99
I am also having the same problem - above PBIX does not load
Thanks in advance
Kevin
