Join the Fabric FabCon Global Hackathon—running virtually through Nov 3. Open to all skill levels. $10,000 in prizes! Register now.
Right click menu is not pop up for drill through
We have a report with drill through enabled from matrix cells : https://msit.powerbi.com/groups/6ffc50ad-e19a-4e3d-ad2d-488ffefedfec/reports/045b7ec5-c7c8-47ae-bba8...  . It is working fine until this morning. The right click menu is not pop up any more. Failed on both edge and chrome. The report is working fine on local desktop. Also tried to republish the report still has the same issue. Please help to check what could be wrong.
-Yan
Status: New
Comments
Shanej
Drill through is working for my workspace now.
This Issue still remains here in UK. Customers are getting impatient ☹️
zelroberic
Mine is still not working.
If a fix has been implemented, is there anything we might need to do to get it working again. Or is it not really a complete fix yet?
thanks,
Rob
adminAtrias
We have the same issue. Throughout our whole organization, this functionality is used a lot. A solution would be welcom.
I do see a workaround by clicking "..." --> Edit --> Explore and turn the drillthrough on --> save...but then the drill can be used maximum once, and goes away again immediately.
ThomasDay
Impactful Individual
@v-chuncz-msft  Things have been fixed.  Whew and thanks.  Looks like the context menu is now also restricted to the correct items...meaning if I've turned off drill up and down etc., they no longer show on the menu.  That's great as well.  Tom
Aggie57
Yes, working for us now 🙂
raj2000
Can confim that it is working for me too.  Thanks for looking into this and getting it fixed.👏
PVu
Hi
I do not see it work in Power BI Desktop. Does anyone have same issue?
Aggie57
Works OK for me in Desktop.  I'm on 2.79.5774.0, installed April 5th.
ThomasDay
@PVu This thread is NOT about right clicks on Desktop, this thread is about right clicks that WORK on Desktop but not in Power BI service.  As far as I know there never has been a problem on desktop.  I'm guessing you've not set up the drillthrough properly.
