Hello
Last week I published the following article:
For a month now, I've been unable to access Power Automate via Power BI (see attached photos). I used to be able to access it without any problems.
My colleagues have the same problem. Do you have any idea where this fault might be coming from?
Thank you for your help
Maxime
Someone suggested the following solution, which worked when I tested it.
Make sure you have sign-in power bi and that use has power automate access.
change setting
Go to File-> Options and settings -> Options -> Security Option -> and check : Use My Default browser( Visible after scroll)
if needed, clear the cache of the default browser.
However, as of this morning, it doesn't work any more, even though I've redone the same procedure. Do you have any idea what could be causing this problem?
Thank you
Maxime
