Problem In Connect to Ziosk Survey Analytics with Power BI
I'm trying to follow the Instructions available at the following link:
https://docs.microsoft.com/en-us/power-bi/service-connect-to-ziosk
When I enter the user and the password I got the following erro:
Message: AADSTS50020: User account 'xxxx@xxxxx.onmicrosoft.com' from identity provider 'https://sts.windows.net/e29064a2-6dfb-4b58-8098-85ef4b0611f5/' does not exist in tenant 'Ziosk' and cannot access the application 'e918c4cb-3bf7-488b-9269-f7a141e4a69a' in that tenant. The account needs to be added as an external user in the tenant first. Sign out and sign in again with a different Azure Active Directory user account.
Advanced diagnostics: Disable
If you plan on getting support for an issue, turn this on and try to reproduce the error. This will collect additional information that will help troubleshoot the issue.
I get into the Azure active directory and the user has the full access privileges without any restrictions, what can I do to solve this problem?
Status: New
Comments
v-qiuyu-msft
Hi @MAAbdullah47,
Are you able to access the Ziosk directly use the same credential which you used to connect to Ziosk content pack?
Qiuyun Yu
MAAbdullah47
Helper V
Thank you for your replay, Actually, I follow the instructions on the link:
I keep following it, but I got the message link as a result of the poor information provided by MS documentation,   for your question :
I didn't register on Ziok so that means I don't have an account on it If this is the problem how I Get sign into Zoik to get credential? Kindly if you have additional information than the (vouge) link on Microsoft please send it to me with much appreciation.
v-qiuyu-msft
Hi @MAAbdullah47,
Would you please turn on the Advanced diagnostics as suggested by error in your initial post:
Then reproduce the issue, share detail information for us.
Qiuyun Yu
MAAbdullah47
Helper V
Ok I did the recommendation it's enabled now with the same error message, pleases look at the attached screenshot:
Please advise.
