Power BI customers using on-premises gateway (personal mode) with a custom connector ....
Power BI customers using on-premises gateway (personal mode) with a custom connector data source attempting to perform on-demand refresh or access Gateway connection from Data settings page may see the error message, "Something went wrong ..Failed to load data sources". Engineers have identified the root cause and a fix is expected to be deployed by end-of-day 08/06/2022.
is the planned date For customers who are still experiencing long running refreshes or refreshes stuck in cancelling state we recommend splitting complex dataflows, limiting the total number of queries per dataflow, and strategically planning scheduled refreshes on premium capacities. We are continuing to invest in further improvements and expect weekly deployment of improvements still 08/29/2022?
Please provide an update and where I can track the future update to this issue.
Thank you
Status: Delivered
Hi @mondy,
It’s a known issue and it should have been fixed according to the inform from the product group. To track the know issue, you could refer to Power BI known issues - Power BI | Microsoft Docs. If you still have problems on it, you may reach support engineers to help. Thanks for your understanding!
Community Support Team _ Caiyun
Comments
AilsaTaoYe
Hi @mondy
You can keep an eye on the link below and it will be updated if there are any developments.
Known issue - Long running, failed or stuck dataflow in Premium Gen2 - Power BI | Microsoft Docs
PavloEstevas
is this fixed yet? IS it causing any other errors such as ""something went wrong - an error occured while rendering the report"?
v-cazheng-msft
Status changed to: Delivered
Hi @mondy,
