Hi Community,
Few days ago, one particular issue appeared in our report's measure on Power BI Service.
Measure is using inactive M:N relationship which is activated in measure using USERELATIONSHIP()
In Power BI Desktop, measure is calculated correctly (realationship is used):
But when I upload file to Power BI Service, from some reason, USERELATIONSHIP is not working:
There is another inactive relationship M:1 which is working fine.
Is there anyone else experiencing this issue? To me it seems as a PBI Service related bug. It was working fine on Service few days ago.
Thanks!
Best,
Michal
