Get certified in Microsoft Fabric—for free! For a limited time, get a free DP-600 exam voucher to use by the end of 2024. Register now
Issue with "Power Automate for Power BI" visual in Power BI Desktop.
When trying to edit the "Power Automate for Power BI" visual in Power BI Desktop, the editing options for adding flows do not appear, and the screen remains blank as shown in the screenshot
I am using the latest version of Power BI Desktop (2.114.664.0 64-bit (feb2023)).
Status: Delivered
Hi @Sanchez_86M
Issue fixed in Power BI Desktop in the latest version . Please update your Desktop version to 2.114.864.0 64-bit (February 2023) and try again .
Comments
v-yetao1-msft
Status changed to: Accepted
Hi @Sanchez_86M
This is indeed a problem . I have submitted it to ICM . I will come back and update if there is any progress .
Ines_SAG
Hi @v-yetao1-msft;
thank you for looking into this, I have the same issue.
Best regards
Ines
EyeMURFather
I am also experiencing the same issue at this time.
JohnPitts4910
Hi @Ailsa-msft;
I am also experiencing the same issue.
BogdanVlad
Same issue. When do we expect to have a solution?
EyeMURFather
Hello - For anyone having this issue - It looks to be a problem with the releases after Nov 2022. I re-installed the November 2022 edition (November 2022 PBI Desktop exe ) Once I did this, the issue was resolved and I was able to once again update Power Automate through PBI Desktop.
Thank you for the solution @cottert
Work Around Solution
JohnPitts4910
Hi @Ailsa-msft;
The problem has disappeared for me.  Is this issue resolved?
v-yetao1-msft
Status changed to: Delivered
Hi @Sanchez_86M
