I have a field parameter slicer to control what fields are shown in a column chart (Y-axis). The X-axis is my time dimension (Year -> Month -> Date). On Power BI desktop, everything works as expected. When I select different fields in my field parameter slicer, only the Y-axis changed. However, when I publish the report to Power BI service, when I select different fields in my field parameter slicer, the time/date dimension is expanded all the way down. It is set by month by default but when I click one of the fields in my slicer, it will expand all down one level in the hierarchy.
