Field Parameter Slicer Works in Power BI Desktop but not Power BI Service
I have a field parameter slicer to control what fields are shown in a column chart (Y-axis). The X-axis is my time dimension (Year -> Month -> Date). On Power BI desktop, everything works as expected. When I select different fields in my field parameter slicer, only the Y-axis changed. However, when I publish the report to Power BI service, when I select different fields in my field parameter slicer, the time/date dimension is expanded all the way down. It is set by month by default but when I click one of the fields in my slicer, it will expand all down one level in the hierarchy.
Status: Delivered
Comments
I do have exactly the same problem and effects as described by @JoshAnness . As soon as I change my multi-selection field parameter slicer in PBI Service my column charts are expanded all down one level in hierarchy on the x-axis. In PBI Desktop everything is fine but published in PBI Service it does not work properly. This only happens since a few days. I haven't had this problem the weeks before.
In addition, I have this problem on my column charts. On tables with the same hierarchies as the column charts (Quarter->Month) everything works fine - in PBI Desktop and Service.
Hi @Anonymous
It's a known issue , the ID is 336190051 . I'll be back with an update if there's any progress .
JinoFung
met same issue when
Y/Q/M in the fields parameter , next levev in date , will good in PBI desktop , but in PBI service , when change the slicer of parameter , all level hierarchy show , just happened since few days ago.
Hi @Anonymous
PG is working on fixing this issue. Should be 3 - 4 weeks for the fix to be in production . Please wait patiently .
joedi
My problem is the opposite. Field parament will work on cloud and app, but wont work on Desktop.
Han_nah
I do have the same problem. Field Parameter is working in PowerBI Desktop but not in PowerBI Server. Is there a workaround?
