0
Drill down dont work when right click and choose drill down in matrix visual in the service
Since wednesday the drill down when clicking right in the matrix-table in a report in the service does not work. It only shows a blank report. When clicking again (left click) inside the visual, it render again. We are on-prem gateway, and connected live with SSAS cubes, mulitdimentional. It works on desktop, but not in the service.
Choosing drill down here; (drill ned)
And this is the result;
When clicking (left click) again inside this, the report renders again.
Status: Delivered
Comments
v-yulgu-msft
Hi @henmor ,
I have reported this problem before, CRI: 115021644.
But it looks like this problem is resolved by itself, Matirx Drill down works as expected now on my side. Please check in your environment.
Best regards,
Yuliana Gu
v-yulgu-msft
Status changed to: Accepted
henmor
Advocate I
I have checked, but it now takes over one minute to show the data. Seems like it doesnt load incremental, but the whole dataset when drilling down.
@v-yulgu-msft Yuliana Gu
henmor
Advocate I
@v-yulgu-msft It works again now!
v-yulgu-msft
Status changed to: Delivered
