Get Fabric Certified for FREE during Fabric Data Days. Don't miss your chance! Learn more
Cusom visual z-index does not render correctly on IE/Edge
I have discovered an issue with custom visuals within Power BI Reports when viewed in Microsoft's IE/Edge browsers.
This affects all custom visuals (both from the store or built by us) so is not something that we have introduced via our custom visual code.
Reproduction Steps:
1) Add a custom drop-down filter or any other visual which expands/collapses.
2) Give the visual enough space (Style Width & Height) in which to expand.
3) Add another visual (any will do) below the custom visual so that its containing box overlaps the one above.
4) Set the z-index/layer which holds the custom visual to the back of the report so that hover/tool-tips/interactions with the other visual is not impaired.
The Issue:
In Chrome/Firefox/Safari - focusing on the custom visual will bring the visual to the top layer, allowing the rendering of any expanding content to show.
In IE/Edge - focusing on the custom visual fails to bring the visual to the front of the report. Any expanding content is hidden behind other visuals.
Notes:
Visuals obtain CSS rules for forcing a z-index.
.explorationContainer.reading .exploreCanvas .visualContainer.selected:hover:not(.popOut) {
z-index: 100001!important;
Custom visuals have their parent 'VisualContainer' div element modified correctly, but the rule is not applied to them, resulting in the 'z-index: 100001!important;' having no effect on the visual.
This rule works and is applied correctly in all other browsers tested by us so far. (Chrome/Firefox on Windows + Chrome/Safari on Mac + Safari on iOS)
Please can this be investigated as it is causing us major issues with clients who use IE & Edge.
Matt
Status: New
Comments
Chrome - Custom visual with correct z-index appliedChrome - Custom visual with correct z-index appliedEdge - z-index not overriden and inline style still appliesEdge - z-index not overriden and inline style still applies
v-qiuyu-msft
Hi @Anonymous,
Which custom visual in the Store you mentioned can reproduce the issue?
@v-viig Is it a known issue?
Qiuyun Yu
Hi @v-qiuyu-msft
The custom visual is 'Smart Filter by OKViz'
This can be found within the Filters category in the marketplace.
Matt
v-viig
Have not seen this issue before.
Can you share a Power BI Desktop report to reproduce it? Can you repro it if you go to Read Mode?
Ignat Vilesov,
Software Engineer
Microsoft Power BI Custom Visuals
pbicvsupport@microsoft.com
v-viig
Ignat Vilesov,
Software Engineer
v-viig
Ignat Vilesov,
Software Engineer
Hi @v-viig
I have uploaded an example report to my file storage in Azure https://powerbicommunity.blob.core.windows.net/public/z-index-ExampleReport.pbix
The issue exists within both Edit & Read modes in app.powerbi.com - and also with embedded reports.
Thanks for helping.
Cheers,
Matt
v-viig
Hi @Anonymous,
I can repro this issue on my PC as well.
@v-qiuyu-msft Can you create a new ticket and ICM?
Ignat Vilesov,
Software Engineer
 Hi @v-viig & @v-qiuyu-msft
Really happy that the sample report was enough to reproduce the issue.
Quick question...
Once a ticket gets created, does it have any public visibility (e.g. can i see if/when it will be actioned) ?
Matt
v-viig
I think this question is for @v-qiuyu-msft.
Ignat Vilesov,
Software Engineer
