Don't miss your chance to take the Fabric Data Engineer (DP-600) exam for FREE! Find out how by watching the DP-600 session on-demand now through April 28th.
Learn moreJoin the FabCon + SQLCon recap series. Up next: Power BI, Real-Time Intelligence, IQ and AI, and Data Factory take center stage. All sessions are available on-demand after the live show. Register now
I would like to merge two tables without creating duplicates in first table. Second table has duplicated IDs, which is what I need.
For example, table 1:
ID Name
1 XX
2 YX
3 YY
Table 2:
ID Info
2 c
2 a
4 b
Currently it does
1 XX m
2 YX c
2 YX a
3 YY
What I want:
1 XX m
2 YX c a
3 YY
Hi, @Vampirtc
Based on your description, i created data to reproduce your scenario. The pbix file is attached in the end.
Table1:
Table2:
You may create a new query with the following m codes in 'Advanced Editor'.
Source = Table.NestedJoin(Table1, {"ID"}, Table2, {"ID"}, "Data", JoinKind.LeftOuter),
Custom1 = Table.TransformColumns(Source,{"Data",each Text.Combine([Info]," "),type text})
Custom1
Result:
Allan
Thank you both that solved the problem.
Hi, @Vampirtc
Table1:
Table2:
Custom1
Result:
Allan
Hello @Vampirtc
the trick here is to no use Table.ExpandTableColumn but use Table.AggregateTableColumn and as a function use Text.Combine.
Table.AggregateTableColumn(Join, "TableB", {{"Info",each Text.Combine(_, " ") , "Info aggregated"}})
Here the complete code
TableA = let
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUXJ0VIrViVYyAjKdnMBMYyDT2VkpNhYA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, Name = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"Name", type text}})
#"Changed Type",
TableB = let
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUUpUitWBsJLALCMgKxnOSgGzjIGsVDgrTSk2FgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, Info = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"Info", type text}})
#"Changed Type",
Join = Table.NestedJoin
TableA,
"ID",
TableB,
"ID",
"TableB",
JoinKind.LeftOuter
#"Aggregated TableB" = Table.AggregateTableColumn(Join, "TableB", {{"Info",each Text.Combine(_, " ") , "Info aggregated"}})
this is the output
Copy paste this code to the advanced editor in a new blank query to see how the solution works.
Kudoes are nice too
Have fun
Jimmy
| 3 | |
| 3 | |
| 2 | |
| 2 | |
| 2 |
| 5 | |
| 4 |
