Vampirtc
5 years agoFrequent Visitor
Problem merging two tables using LEFT Outer join
I would like to merge two tables without creating duplicates in first table. Second table has duplicated IDs, which is what I need. For example, table 1: ID Name 1 XX 2 YX 3 YY Table ...
- 5 years ago
Hi, Vampirtc
Based on your description, i created data to reproduce your scenario. The pbix file is attached in the end.
Table1:
Table2:
You may create a new query with the following m codes in 'Advanced Editor'.
let Source = Table.NestedJoin(Table1, {"ID"}, Table2, {"ID"}, "Data", JoinKind.LeftOuter), Custom1 = Table.TransformColumns(Source,{"Data",each Text.Combine([Info]," "),type text}) in Custom1Result:
Allan
Vampirtc
Thank you both that solved the problem.
