Vampirtc's avatar
Vampirtc
5 years ago
Problem merging two tables using LEFT Outer join
I would like to merge two tables without creating duplicates in first table. Second table has duplicated IDs, which is what I need.
For example, table 1:
ID  Name
1   XX
2   YX
3   YY
Table 2:
ID  Info
2 c
2 a
4 b
Currently it does
1   XX m
2   YX c
2   YX a
3   YY
What I want:
1   XX m
2   YX c a
3   YY
  • Hi, Vampirtc
    Based on your description, i created data to reproduce your scenario. The pbix file is attached in the end.
    Table1:
    Table2:
    You may create a new query with the following m codes in 'Advanced Editor'.
        Source = Table.NestedJoin(Table1, {"ID"}, Table2, {"ID"}, "Data", JoinKind.LeftOuter),
        Custom1 = Table.TransformColumns(Source,{"Data",each Text.Combine([Info]," "),type text})
        Custom1
    Result:
    Allan
  • Jimmy801's avatar
    Jimmy801
    Hello Vampirtc
    the trick here is to no use Table.ExpandTableColumn but use Table.AggregateTableColumn and as a function use Text.Combine.
    Table.AggregateTableColumn(Join, "TableB", {{"Info",each Text.Combine(_, " ") , "Info aggregated"}})
     Here the complete code
        TableA = let
                Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUXJ0VIrViVYyAjKdnMBMYyDT2VkpNhYA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, Name = _t]),
                #"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"Name", type text}})
                #"Changed Type",
        TableB = let
                Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUUpUitWBsJLALCMgKxnOSgGzjIGsVDgrTSk2FgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, Info = _t]),
                #"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"Info", type text}})
                #"Changed Type",
        Join = Table.NestedJoin
            TableA,
            "ID",
            TableB,
            "ID",
            "TableB",
            JoinKind.LeftOuter
        #"Aggregated TableB" = Table.AggregateTableColumn(Join, "TableB", {{"Info",each Text.Combine(_, " ") , "Info aggregated"}})
    this is the output
    Copy paste this code to the advanced editor in a new blank query to see how the solution works.
    Kudoes are nice too
    Have fun
    Jimmy
  • v-alq-msft's avatar
    v-alq-msft
    Hi, Vampirtc
    Table1:
    Table2:
        Custom1
    Result:
    Allan
