Learn moreDid you hear? There's a new SQL AI Developer certification (DP-800). Start preparing now and be one of the first to get certified. Register now
Hi all,
I'd like to create a column that returns a True / False based on the minimum value in a column per each type. I'm not the best at explaining - please take a look at the example:
Thanks for taking a look!
Here is a step by step way to do it in Power Query:
1) Group by the columns to get the max value, somethin like below:
2) Apply a left outer join to merge the main table and the grouped by table:
= Table.NestedJoin(#"Changed Type", {"Value","Type"}, #"Grouped Rows", {"New","Type"}, "Grouped Rows", JoinKind.LeftOuter)3) Now expand the columns to get final Result column:
= Table.ExpandTableColumn(#"Merged Queries", "Grouped Rows", {"New"}, {"Result"})
4) Now replace the values as per your requirement
= Table.ReplaceValue(#"Expanded Grouped Rows", each [Result],each if [Result] = null then "False" else "True",Replacer.ReplaceValue,{"Result"})Complete M Code:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WCs5PzlbSUTJUitUBcjIyi0qAPGMUnikKzxLKy08tRlIJ4QFNiQUA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Type = _t, Value = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Type", type text}, {"Value", Int64.Type}}),
#"Grouped Rows" = Table.Group(#"Changed Type", {"Type"}, {{"New", each List.Min([Value]), type nullable number}}),
#"Merged Queries" = Table.NestedJoin(#"Changed Type", {"Value","Type"}, #"Grouped Rows", {"New","Type"}, "Grouped Rows", JoinKind.LeftOuter),
#"Expanded Grouped Rows" = Table.ExpandTableColumn(#"Merged Queries", "Grouped Rows", {"New"}, {"Result"}),
#"Replaced Value" = Table.ReplaceValue(#"Expanded Grouped Rows", each [Result],each if [Result] = null then "False" else "True",Replacer.ReplaceValue,{"Result"})
#"Replaced Value"
#"Replaced Value"
Hi @peterso
Paste it to Advanced Editor:
Json.Document(
Binary.Decompress(
Binary.FromText(
Compression.Deflate
#"Changed Type" = Table.TransformColumnTypes(Source, {{"Type", type text}, {"Value", Int64.Type}}),
MinValue = Table.Group(
#"Changed Type",
{"Type"},
{{"Min", each List.Min([Value]), type nullable number}}
#"Changed Type",
{"Type"},
MinValue,
{"Type"},
"Changed Type",
JoinKind.LeftOuter
#"Expanded Changed Type" = Table.ExpandTableColumn(
#"Merged Queries",
"Changed Type",
{"Min"},
{"Min"}
#"Added Custom" = Table.AddColumn(#"Expanded Changed Type", "Result", each [Value] = [Min]),
#"Removed Columns" = Table.RemoveColumns(#"Added Custom", {"Min"})
#"Removed Columns"
