Learn moreJoin the FabCon + SQLCon recap series. Up next: Power BI, Real-Time Intelligence, IQ and AI, and Data Factory take center stage. All sessions are available on-demand after the live show. Register now
This is an Advanced problem in M language with a very simple excel formula solution.
And after many tryouts with many codes, I am kindly asking for Help, please.
I have managed to do the grouped running total in various methods yet could not twist any of the codes to achieve the below excel example.
The question is how to do a group running total that evaluates each step that if the next added line will be greater than the calculation of the passed variable and the sum up to this point and if it is greater than that calculation it adds the calculation to the sum and continues running total with the passed calculation.
Data is as simple as 3 columns: Filter - to group on, Volume - to sum up, and Cube - as a variable to perform the calculation.
Here are the basic example of excel files explaining the problem statement
in Line F10 you can see that formula triggers the if statement, that if the running total in F10(adding B10; B10 Greater than J9) is greater than Remaining space in J9 then it adds the J9 to the running total.
Where J9 is the calculation based on F9 and C9 etc...
This is the Example data with desire outcome
Here are the formulas
The best M code so far was by following the link below
Here is my code
`(values as list, grouping as list, cube as list) as list =>
let GRTList = List.Generate
( ()=> [ GRT = values{0}, i =0, cube =0],
each [i] < List.Count(values),
each try if grouping{[i]} = grouping{[i]+1}
and [GRT = [GRT] + values{[i]+1}, i=[i]+1]> Number.RoundUp([GRT]/
cube)*cube
then [GRT = [GRT] + values{[i]+1}, i=[i]+1]+((
Number.RoundUp([GRT]/ cube)*cube) -[GRT])
else [GRT = [GRT] + values{[i]+1}, i=[i]+1]
otherwise [i= [i]+1],
each[GRT]
GRTListAnd here is the callout function
#"Added Index" = Table.AddIndexColumn(#"Sorted Rows", "Index", 0,
1, Int64.Type),
BufferedTable5 = Table.Buffer(#"Added Index"),
BufferedValues = List.Buffer(BufferedTable5[Volume]),
BufferedFilter = List.Buffer(BufferedTable5[Filter for Running
total_Drop_Level]),
BufferedCube = List.Buffer(BufferedTable5[Cube Per Posission]),
RT = Table.FromColumns({BufferedTable5[Filter for Running
total_Drop_Level],BufferedTable5[Volume],
fxGroupedRunningTotal(BufferedValues,BufferedFilter,BufferedCube)},Many thanks,
Hi @SpreadsheetPete,
This is probably not the neatiest solution, but you can try something like this:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amQMpQKVYHLm6KEDdCFjdHiBvjUG+CLG6JEDcFizth2GuGLI5kjjmyOJK9FmBxZwxxSyRxEyRzDA2QNSA5yBDo41gA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t, Index = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}, {"Index", type text}}),
Aggregate = List.Accumulate(Table.ToRecords(#"Changed Type"), {}, (a,n)=> a & {
Record.AddField(Record.AddField(n, "CubeFill", n[Volume] + (if List.IsEmpty(a) or List.Last(a)[CubeFill] + n[Volume] > n[Cube] or List.Last(a)[Filter] <> n[Filter] then 0 else List.Last(a)[CubeFill])),
"PositionCount", if List.IsEmpty(a) or List.Last(a)[Filter] <> n[Filter] then 1 else if List.Last(a)[CubeFill] + n[Volume] > n[Cube] then List.Last(a)[PositionCount]+Number.RoundUp(n[Volume]/n[Cube], 0) else List.Last(a)[PositionCount])}),
Output = Table.FromRecords(Aggregate)
Output
Kind regards,
John
I corrected the code in fxCalc.
(A)=>
RunningTotal = Table.AddColumn(
A,
"Running Total",
each
if [Volume] <
(Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube])
- List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0}))
then @RunningTotal[Running Total]{[Index]-1} + [Volume]
else List.Sum(List.FirstN(A[Volume],[Index]+1))
+ ((Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube])
- List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})))
CubeFill = Table.AddColumn(
RunningTotal,
"Cube Fill",
each [Running Total]/[Cube]
PositionCount = Table.AddColumn(
CubeFill,
"Position Count",
each Number.RoundUp([Cube Fill],0)
RemainingSpace = Table.AddColumn(
PositionCount,
"Remaining Space",
each [Position Count] * [Cube] - [Running Total]
RemainingSpace
Main Query:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amSrE6cDFTLGLmRKqzRBZzwmKHExa9TljscMYpZmKKRR3C3lgA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}}),
#"Grouped Rows" = Table.Group(#"Changed Type", {"Filter"}, {{"Group", each fxCalc(Table.AddIndexColumn(_,"Index",0,1))}}),
Combine = Table.Combine(#"Grouped Rows"[Group])
Combine
Regards
KT
HI @SpreadsheetPete ,
The challenge I can foresee now is the cyclic reference based on your excel formula between the Remaining Space and Running Total column. I will have an attempt with the recursive method later and let you know if any luck.
Regards
KT
Amazing Thank you
I did have some luck by adopting the below code and it works very closely yet it causes missed calculations after only some of the records. here is my latest code.
Also here is the updated Excel file demonstrating the output of the code and the error
the best code so far
Source = Excel.CurrentWorkbook(){[Name="SourceTable"]}[Content],
#"Added Index" = Table.AddIndexColumn(Source, "Index", 0, 1,
Int64.Type),
CorrectTypes = Table.TransformColumnTypes(#"Added Index",{{"Index",
Int64.Type}, {"Filter", type text}, {"Volume", type number}}),
each List.Sum(Table.SelectRows(CorrectTypes, (Q) => Q[Filter] =
[Filter] and Q[Index] <= [Index])[Volume]), type number),
Runing = Table.Group(CorrectTypes,"Filter",{"A", each let
A = Table.AddIndexColumn(_,"i")
in Table.AddColumn(A,"R", each
List.Accumulate(Table.SelectRows(A, (a)=> a[i]<=[i])[Volume],
[Running=0, Verifier = 1],
// Here the challenge begins
(s,l)=> [Running = if s[Running]+l >
(Number.RoundUp(s[Running]+[Volume]/[Cube])*[Cube]) then
((Number.RoundUp(s[Running]/[Cube])*[Cube])-s[Running])+s[Running]+
[Volume] else s[Running]+l , Verifier =Number.From(s[Running]+l
<=Number.RoundUp(s[Running]/[Cube])*[Cube] )] ))
ExpandedR = Table.ExpandRecordColumn(
Table.ExpandTableColumn(Runing, "A", {"Volume","Cube","i", "R"}),
"R", {"Running", "Verifier"})
and here is the output
Code Output and formulas with desired outcome
Hi @SpreadsheetPete ,
Please see below code (There are still a slight variance in the calculation which I will look into it tomorrow.)
Working query:
Combine
fxCalc:
(A)=>
A,
"Running Total",
each
if [Volume] <
then List.Sum(List.FirstN(A[Volume],[Index]+1))
RunningTotal,
"Cube Fill",
CubeFill,
"Position Count",
PositionCount,
"Remaining Space",
RemainingSpace
Regards
KT
(A)=>
A,
"Running Total",
each
if [Volume] <
RunningTotal,
"Cube Fill",
CubeFill,
"Position Count",
PositionCount,
"Remaining Space",
RemainingSpace
Main Query:
Combine
Regards
KT
KT
THANK YOU VERY MUCH!!!
You Are The Winner Here as your code does exactly what I was struggling with for over a week now.
This is absolutely amazing! I cannot thank you enough
Beautiful work!
John,
Thank you to you too as your code is also very good and very useful and it has provided me a different perspective To my challenge so also very grateful for your work.
You are both lifesavers!
Kind Regards
Pete
Output
Kind regards,
John
Hi John,
Thank you for the help, your code does the job only to a certain point
Where in 3rd step of calculation for Filter "A" adds to 0.14 the 0.05 it should add the remaining space from cube (0.15 - 0.14 = 0.1) to the current calculation 0.14+0.01 and then add the next line 0.05... the code reset and just start from 0.05 so it's missing the whole challenge I am facing 🙂 - I need Running total for entire Filter A but when remaining space is less than next cube to add it needs to absorb the remaining space to the running total.
One hint of observation to note with this code, it heavily depends on the filter being sorted in group order before the index applies. if the filter is not sorted like AAABBBCCC and left as ABAABBACA it will just give possession 1 to every step...so wonder if we should apply the index to each grouped list.. rather than to the table...
Hi John,
After dipper analysis of your code, it might not give me exactly what I was looking for but actually, it produces better results than I could hope for, it gives me the correct position against the cube. meaning I can simplify my further steps by adopting a different perspective to my problem. Amazing WORK!!! Thank you Very Much!!!
PS
If you do have an idea how to twist the code to earlier comments that would be great help /learning, please. I am just so curious by now how I should have done it, hate to be defeated by a code 😉
It will cause me a sleep less nights till I resolve this challenge.
Kind regards
Pete
