SpreadsheetPete
4 years agoRegular Visitor
Power Query Conditional Running Total with If Statement - Advanced Problem
Hi, This is an Advanced problem in M language with a very simple excel formula solution. And after many tryouts with many codes, I am kindly asking for Help, please. I have managed to do the gr...
- 4 years ago
Hi SpreadsheetPete,
This is probably not the neatiest solution, but you can try something like this:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amQMpQKVYHLm6KEDdCFjdHiBvjUG+CLG6JEDcFizth2GuGLI5kjjmyOJK9FmBxZwxxSyRxEyRzDA2QNSA5yBDo41gA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t, Index = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}, {"Index", type text}}), Aggregate = List.Accumulate(Table.ToRecords(#"Changed Type"), {}, (a,n)=> a & { Record.AddField(Record.AddField(n, "CubeFill", n[Volume] + (if List.IsEmpty(a) or List.Last(a)[CubeFill] + n[Volume] > n[Cube] or List.Last(a)[Filter] <> n[Filter] then 0 else List.Last(a)[CubeFill])), "PositionCount", if List.IsEmpty(a) or List.Last(a)[Filter] <> n[Filter] then 1 else if List.Last(a)[CubeFill] + n[Volume] > n[Cube] then List.Last(a)[PositionCount]+Number.RoundUp(n[Volume]/n[Cube], 0) else List.Last(a)[PositionCount])}), Output = Table.FromRecords(Aggregate) in OutputKind regards,
John
- 4 years ago
I corrected the code in fxCalc.
(A)=> let RunningTotal = Table.AddColumn( A, "Running Total", each if [Volume] < (Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube]) - List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) then @RunningTotal[Running Total]{[Index]-1} + [Volume] else List.Sum(List.FirstN(A[Volume],[Index]+1)) + ((Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube]) - List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0}))) ), CubeFill = Table.AddColumn( RunningTotal, "Cube Fill", each [Running Total]/[Cube] ), PositionCount = Table.AddColumn( CubeFill, "Position Count", each Number.RoundUp([Cube Fill],0) ), RemainingSpace = Table.AddColumn( PositionCount, "Remaining Space", each [Position Count] * [Cube] - [Running Total] ) in RemainingSpaceMain Query:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amSrE6cDFTLGLmRKqzRBZzwmKHExa9TljscMYpZmKKRR3C3lgA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"Filter"}, {{"Group", each fxCalc(Table.AddIndexColumn(_,"Index",0,1))}}), Combine = Table.Combine(#"Grouped Rows"[Group]) in CombineRegards
KT
jbwtp
4 years agoMemorable Member
Hi SpreadsheetPete,
Output
Kind regards,
John
