Power Query Conditional Running Total with If Statement - Advanced Problem
- 4 years ago
Hi SpreadsheetPete,
This is probably not the neatiest solution, but you can try something like this:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amQMpQKVYHLm6KEDdCFjdHiBvjUG+CLG6JEDcFizth2GuGLI5kjjmyOJK9FmBxZwxxSyRxEyRzDA2QNSA5yBDo41gA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t, Index = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}, {"Index", type text}}), Aggregate = List.Accumulate(Table.ToRecords(#"Changed Type"), {}, (a,n)=> a & { Record.AddField(Record.AddField(n, "CubeFill", n[Volume] + (if List.IsEmpty(a) or List.Last(a)[CubeFill] + n[Volume] > n[Cube] or List.Last(a)[Filter] <> n[Filter] then 0 else List.Last(a)[CubeFill])), "PositionCount", if List.IsEmpty(a) or List.Last(a)[Filter] <> n[Filter] then 1 else if List.Last(a)[CubeFill] + n[Volume] > n[Cube] then List.Last(a)[PositionCount]+Number.RoundUp(n[Volume]/n[Cube], 0) else List.Last(a)[PositionCount])}), Output = Table.FromRecords(Aggregate) in OutputKind regards,
John
- 4 years ago
I corrected the code in fxCalc.
(A)=> let RunningTotal = Table.AddColumn( A, "Running Total", each if [Volume] < (Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube]) - List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) then @RunningTotal[Running Total]{[Index]-1} + [Volume] else List.Sum(List.FirstN(A[Volume],[Index]+1)) + ((Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube]) - List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0}))) ), CubeFill = Table.AddColumn( RunningTotal, "Cube Fill", each [Running Total]/[Cube] ), PositionCount = Table.AddColumn( CubeFill, "Position Count", each Number.RoundUp([Cube Fill],0) ), RemainingSpace = Table.AddColumn( PositionCount, "Remaining Space", each [Position Count] * [Cube] - [Running Total] ) in RemainingSpaceMain Query:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amSrE6cDFTLGLmRKqzRBZzwmKHExa9TljscMYpZmKKRR3C3lgA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"Filter"}, {{"Group", each fxCalc(Table.AddIndexColumn(_,"Index",0,1))}}), Combine = Table.Combine(#"Grouped Rows"[Group]) in CombineRegards
KT
Hi John,
Thank you for the help, your code does the job only to a certain point
Where in 3rd step of calculation for Filter "A" adds to 0.14 the 0.05 it should add the remaining space from cube (0.15 - 0.14 = 0.1) to the current calculation 0.14+0.01 and then add the next line 0.05... the code reset and just start from 0.05 so it's missing the whole challenge I am facing 🙂 - I need Running total for entire Filter A but when remaining space is less than next cube to add it needs to absorb the remaining space to the running total.
Hi John,
After dipper analysis of your code, it might not give me exactly what I was looking for but actually, it produces better results than I could hope for, it gives me the correct position against the cube. meaning I can simplify my further steps by adopting a different perspective to my problem. Amazing WORK!!! Thank you Very Much!!!
PS
If you do have an idea how to twist the code to earlier comments that would be great help /learning, please. I am just so curious by now how I should have done it, hate to be defeated by a code 😉
It will cause me a sleep less nights till I resolve this challenge.
Kind regards
Pete
