HI,
I would like to know below option is available or not.
1. Is it possible to integrate Power BI reports with Web application?
2. Is it possible to integrate Power BI reports with native mobile App (calling power bi report from another app)?
3. Is it possible to integrate dashDB for Power BI reports.
SM
Hi @Sandeep,
Firstly, you are able to integrate Power BI reports with Web application by using Power BI API, for more details, please review this article: Integrate a report into an app.
Secondly, Microsoft provides Power BI mobile apps to view Power BI reports, you are able to see reports directly in iOS, Android and Windows apps, you can get more details in this article: Power BI apps for mobile devices.
Thirdly, do you want to connect to IBM dashDB from Power BI and create reports? If that is the case, you can create a ODBC data source for IBM dashDB following the instructions in this article, then connect to the ODBC data source from Power BI Desktop. This way, you are able to create reports using data in IBM dashDB and publish the reports into Power BI Service.
Lydia Zhang
Hi @Sandeep,
Based on the following sources, you are able to integrate Power BI report into mobile applications.
Bring the Power into Your Application; Power BI Embedded
PowerBI-CSharp
Lydia Zhang
Hi @Sandeep,
Lydia Zhang
Thanks @Anonymous for response.
1. Is this possible to integrate Power BI reports to customer native mobile app.
(this is one of the requirement)
SM
Hi @Anonymous,
Let me explain more:
Let's say, we have an mobile app called "MyApp" and would like to integrate "Power BI" reports by clicking some options in side "MyApp". here I am saying, I will not be using "Power BI Mobile" app.
So brief you more, customer has already an Mobile App (iOS and Android) which are widely used by its employee. so they want to integrate "Power BI reports" with this Mobile App making a single sign on options. So no need to use different app to access reports.
Hope this helps.
Sandeep
Hi @Sandeep,
PowerBI-CSharp
Lydia Zhang
Thanks @Anonymous, much appriciate your help 🙂
Regards
SM
Dear Team,
SM
| 3 | |
| 3 | |
| 2 | |
| 1 | |
| 1 |
