MauricioBI
Using same Personal Gateway with two differente SQL Data Bases??
How to connect two different databases on different servers with using same Personal Gateway?
is possible to have a single personal gateway to two databases on different servers?
@MauricioBI This should just work as long as the 2 servers are in the same domain. The only time you need multiple gateways now is if you are using Tabular models. Then you would need to spin up a gateway for each instance on seperate machines. Another option you can explore is the Enterprise Gateway, so take note of that.
HarrisMalik
Continued Contributor
For multiple servers Enterprise Gateway is the way to go.
Cheers
Harris
@Anonymous, @HarrisMalik I'll install the Enterprise Gateway right now and will comment you if resolve my problem.
Fabric SQL PBI Data Days
Data Days 2026 coming soon!
