Hi, im having some issues creating a new column that calculates the distance between two points.
I have the latitude and longitude of both points, created a new column to give me the kilometers between these two points but all i got is a 0 in return.
Below is the formula im using and a screenshot of the points i have.
KM =
var x1 = RADIANS(SELECTEDVALUE(DMS[LAT OR]))
var x2 = RADIANS(SELECTEDVALUE(DMS[LAT DEST]))
var y1 = RADIANS(SELECTEDVALUE(DMS[LON OR]))
var y2 = RADIANS(SELECTEDVALUE(DMS[LON DEST]))
var R = 6371
var lcos = ROUND(SIN(x1)*SIN(x2)+cos(x1)*cos(x2)*cos(y1-y2),15)
var arco = ACOS(lcos)
return
arco*R
This is a column, so you should not use SELECTEDVALUE
The formula you wrote would work great in a measure, but not in a column. The column should be:
KM =
var x1 = RADIANS(DMS[LAT OR])
var x2 = RADIANS(DMS[LAT DEST])
var y1 = RADIANS(DMS[LON OR])
var y2 = RADIANS(DMS[LON DEST])
var R = 6371
var lcos = SIN(x1)*SIN(x2)+cos(x1)*cos(x2)*cos(y1-y2)
return
arco*R
Although using a measure would be much better for memory if you increase your table size.
Did I answer your question? Mark my post as a solution! Proud to be a Super User!
Connect with me!
Stay up to date on
Read my blogs on
Hi tayusso. Nice to meet you. I wonder if you have found a solution to this problem:
Solved: Problem calculating distance between two points wi... - Microsoft Power BI Community
I have the same problem and I can't find a solution.
In a column, if you write the number directly inside the ACOS() function it returns a correct answer, like this: Distance = ACOS(0.896494) = 2.924,31 Km
Could you help me please?
Felipe Baritto (Venezuela)
KM =
var R = 6371
return
arco*R
Connect with me!
Stay up to date on
Read my blogs on
| 8 | |
| 7 | |
| 7 | |
| 3 |
