tayusso
5 years agoNew Member
Problem calculating distance between two points with Latitude and longitude
Hi, im having some issues creating a new column that calculates the distance between two points. I have the latitude and longitude of both points, created a new column to give me the kilometers betw...
- 5 years ago
This is a column, so you should not use SELECTEDVALUE
The formula you wrote would work great in a measure, but not in a column. The column should be:
KM = var x1 = RADIANS(DMS[LAT OR]) var x2 = RADIANS(DMS[LAT DEST]) var y1 = RADIANS(DMS[LON OR]) var y2 = RADIANS(DMS[LON DEST]) var R = 6371 var lcos = SIN(x1)*SIN(x2)+cos(x1)*cos(x2)*cos(y1-y2) var arco = ACOS(lcos) return arco*RAlthough using a measure would be much better for memory if you increase your table size.
FBaritto
3 years agoNew Member
Hi tayusso. Nice to meet you. I wonder if you have found a solution to this problem:
Solved: Problem calculating distance between two points wi... - Microsoft Power BI Community
I have the same problem and I can't find a solution.
In a column, if you write the number directly inside the ACOS() function it returns a correct answer, like this: Distance = ACOS(0.896494) = 2.924,31 Km
Could you help me please?
Felipe Baritto (Venezuela)
