Simon_29
Helper II
Helper II
Power query has a problem with decimal places under conditions
I have a problem that under the condition in Power Query, which I highlighted in yellow, the column called "Check 70% Margin" gives an incorrect output in the form of "no" as can be seen in the picture. In the first line (when I count integers) it throws the correct output, but in decimal numbers (the second line) it gives the output as "no" and there is a correct result.
Has anyone already had a similar problem that you could refer me to him?
Thank you very much for your help.
Vera_33
Resident Rockstar
Resident Rockstar
Hi @Simon_29
You can use Number.Round:
Number.Round( [Column2]/[Column1],1)=0.7
FarhanAhmed
Your column Submitted TCV has an unassigned data type. change the type to decimal for both Submitted columns and check your results.
Did I answer your question? Mark my post as a solution! Appreciate your Kudos!!
I've tried this before and it didn't work. However, Vera33 below in this post gave the right solution and it already works.
Thank you very much 🙂
Vera_33
Resident Rockstar
Resident Rockstar
Hi @Simon_29
Hi Vera:)
Your solution worked. I had never thought of such a possibility before.
Thank you very much:)
