sfog's avatar
sfog
Icon for Advocate II rankAdvocate II
5 years ago
Power Query seems to hang when I click Close and Apply
Hi I have a simple power query that sorts a column, and a step to determine when a value changes in the sorted column. This step that determines if the value changes seems to cause the query to hang...
  • sfog's avatar
    5 years ago
    Hi
    I managed to solve it with a workaround.
    My requirement was to compare the current row with the previous row - so all I did was:
    - remove the line that used the index (-1) to compare to the previous row
    - adding a new column (index + 1)
    -  merge the current query with itself (on the index and index+1 columns)
