Hi guys,
I’m kinda new to accessing APIs in general and I’m not really a coder. Nevertheless, I feel I must be close with this. Can anyone tell me how to fix my Power Query? It must be something super simple…
API key redacted, of course.
The Power Query editor errors saying “Token Comma Expected” and highlighting the colon after “boards (ids” in the following query:
Source = Web.Contents("https://api.monday.com/v2/", [Headers=[Authorization="Bearer myapikey", #"Method"="GET",
#"Content-Type"="application/json"]]
boards (ids:[000000000, 000000000]) {
items {
name
id
column_values{
text
Source
Hello @Anonymous
setting up an api with Power Query is quite complex and needs very specific knowlege of Power query but also of the api you are trying to query.
We here in the forum are doing this all voluntarily and you may have problems finding someone that is willing to spent so much time on a issue. Maybe it would be best to contact a professional to create such a query.
I've posted an example how this has to be done in your case.
Jimmy
Hi @Anonymous
try to remove comma "," before in statement:
Source
do not hesitate to give a kudo to useful posts and mark solutions as solution
Hi @az38
Thank you so much for the fast reply. I tried your suggestion, but sadly it still highlights that comma and says Token Comma Expected.
@Anonymous
not sure but it seems the code should look like
#"Content-Type"="application/json"]],
items {
name,
id,
column_values{
text
Source
@az38 still no joy, I'm afraid. Same issue persists.
I have put this up on the monday.com dev forums too, but it's a ghost town over there.
Hello @Anonymous
the error is coming from here
i think you have to put all in quotes and double quotes and use some content record where you have to feed a JSON-Document into a Text.FromBinary
See here an example
content = "{
""method"": ""get"",
""params"": {
""SelectionCriteria"": {},
""FieldNames"": [""Id"", ""Name""]
Source = Json.Document(Web.Contents("https://api-sandbox.direct.yandex.com/json/v5/campaigns", [Headers=[Authorization="Bearer AQAAAAANlKwBAAQQn4Wfgbxxxxxxxxxx"], Content=Text.ToBinary(content)]))
Source
Hope this helps
Jimmy
@Jimmy801 , thank you but i'm too noob to know quite what you mean. i tried putting my url and API key into your example and the following for the query:
content = "{
""params"": {
""boards"" {
""name""
}",but ended up with a result saying "No query string was present"
@az38 i've simplified the query to the following:
boards {
name
Source
and no more syntax errors in the editor! but, on clicking done, I get: "Expression.Error: The name 'boards' wasn't recognized. Make sure it's spelled correctly."
Hello @Anonymous
did you implement it like in my example? Meaning inputing in a variable and then applying to web.Contents as parameter with content= Text.FromBinary?
Jimmy
@Jimmy801 I'm pretty certain that I did not, seeing as I don't know what you mean! I know you're trying to be helpful, but I'm very new to Power Query/Power BI and no real experince with coding before that.
*cries all over his noob clothes*
Hello @Anonymous
Jimmy
(it's a GraphQL API, if that makes any difference)
@Anonymous
it's difficult to try without access to source, but this should give you more understandable error
#"Content-Type"="application/json"],Query="{
items {
name
id
column_values{
text
#"Imported JSON" = Json.Document(Source,1252)
#"Imported JSON"
@az38 That made the editor happy with all the syntax. After converting the result to a table etc, i end up with a message saying "no query string was present".
I've created a trail account on monday.com for you, so feel free to use the api key: eyJhbGciOiJIUzI1NiJ9.eyJ0aWQiOjMwMTk0MjY4LCJ1aWQiOjEyMDIxMzI1LCJpYWQiOiIyMDIwLTAxLTA3IDEzOjAyOjM1IFVUQyIsInBlciI6Im1lOndyaXRlIn0.5ksF8oi27hneEcfAiTrj5MNVV-4SW-Fh3KxTUZMpBII
I just need to get to a point where I can put my own queries in. They have a useful "try it yourself" site for the API, which I've been getting on with well: https://monday.com/developers/v2/try-it-yourself
| 2 | |
| 2 | |
| 1 |
| 11 | |
| 11 | |
| 5 | |
| 4 |
