AOT
Help with M power query
I need to filter a column have dates between DateTime.FixedLocalNow()) and Date.AddDays((DateTime.FixedLocalNow()), 91)).
But I cannot seem to get the right M query script.
Please help.
This is currently what I have done. But it doesn't seem to filter the column properly. The column is [end_date]
#"Filtered Rows2" = Table.SelectRows(#"Changed Type", each [end_date] > DateTime.FixedLocalNow()),
#"Filtered Rows3" = Table.SelectRows(#"Changed Type", each [end_date] < Date.AddDays((DateTime.FixedLocalNow()), 91))
Hi @AOT
Not sure if I've understood your requirement correctly, but I believe this should work as a replacement for your #"Filtered Rows2" step:
#"Filtered Rows2" = Table.SelectRows(#"Extracted Date1", each Date.From([end_date]) = Date.From(DateTime.FixedLocalNow()) or Date.IsInNextNDays(Date.From([end_date]), 91)),
I've used the Date.From() surrounds on the [end_date] column refs so you aren't required to use your "Extracted Date" step if you don't want to.
Remember to remove the comma at the end if this is the last step in your query
Pete
Proud to be a Datanaut!
v-frfei-msft
Hi @AOT ,
If you want to make your code work, you should change your date to date.time. Or you can update your M code as below.
= Table.SelectRows(#"Changed Type", each [Date] >= Date.From(DateTime.FixedLocalNow()) and [Date] <= Date.From(Date.AddDays((DateTime.FixedLocalNow()), 91)))
Full code for your reference as well.
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("Vc65DcAwDMXQXVQHsL7sHJ5F8P5ruEgQUOUDG2aamlq4pq0jLYhODOIkLuImHmIS8qLyoDLxpnDsfejE+LE2", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [Date = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Date", type date}}),
    #"Filtered Rows" = Table.SelectRows(#"Changed Type", each [Date] >= Date.From(DateTime.FixedLocalNow()) and [Date] <= Date.From(Date.AddDays((DateTime.FixedLocalNow()), 91)))
    #"Filtered Rows"
Community Support Team _ Frank
If this post helps, then please consider Accept it as the solution to help the others find it more quickly.
Hi @v-frfei-msft ,
When I put in the step, there are no syntax errors but I keep on getting this error. Do you know what this means?
Hi @AOT ,
Could you please share your sample data or pbix to me if you don't have any Confidential Information. Please upload your files to One Drive and share the link here.
Hi @v-frfei-msft ,
This is the code so far
Source = Impala.Database("impalahs2dr.unix.marksandspencer.com:25003"),
spotfire_reporting_views_Schema = Source{[Name="spotfire_reporting_views",Kind="Schema"]}[Data],
t_irp_phase_new_sc_Table = spotfire_reporting_views_Schema{[Name="t_irp_phase_new_sc",Kind="Table"]}[Data],
#"Added Conditional Column" = Table.AddColumn(t_irp_phase_new_sc_Table, "articlev", each if [variant_no] = null then [article_id] else [variant_no]),
#"Changed Type" = Table.TransformColumnTypes(#"Added Conditional Column",{{"start_date", type datetime}, {"end_date", type datetime}}),
#"Extracted Date" = Table.TransformColumns(#"Changed Type",{{"start_date", DateTime.Date, type date}}),
#"Filtered Rows1" = Table.SelectRows(#"Extracted Date", each [start_date] > Date.From(DateTime.FixedLocalNow())),
#"Extracted Date1" = Table.TransformColumns(#"Filtered Rows1", {{"end_date", DateTime.Date, type date}}),
#"Filtered Rows2" = Table.SelectRows(#"Extracted Date1", each [end_date] <= Date.From(Date.AddDays((DateTime.FixedLocalNow()), 84)) and [end_date] >= Date.From(DateTime.FixedLocalNow())),
Hi @AOT
Pete
Mariusz
Hi @AOT
If your column is a date data type then try adding Date.From( DateTime.FixedLocalNow() ) around this should work.
Mariusz
If this post helps, then please consider Accepting it as the solution.
May Power BI Update Carousel
Fabric SQL PBI Data Days
Data Days 2026 coming soon!
