JaclynPugh2022
Helper II
Helper II
Power Query Custom Column Help Please
I'm trying to write a custom field that looks at [Late/Early/On-Time] and if there is an error I need it to populate with "Unconfirmed".  Any help would be appreciated.  Thank you!
m_alireza
Solution Specialist
Solution Specialist
Hi @JaclynPugh2022 ,
Alternatively, you could right click on the column > Replace Errors...
Then Type Unconfirmed and press ok.
That should replace the errors in your field with Unconfirmed
AntrikshSharma
@JaclynPugh2022 if (try [Column] )[HasError] then "Unconfirmed" else [Column]
m_alireza
Solution Specialist
Solution Specialist
May Power BI Update Carousel
Fabric SQL PBI Data Days
Data Days 2026 coming soon!
