ToddChitt
Power Query Auto Complete does not work well
Having an 'auto complete' feature in a coding language is great.
When it work right.
Power Query auto complete does NOT.
Try this: Open a query and click the Custom Column on the Add Column menu. The dialog box opens where you input your M language statement.
Now type into the formula box "Text.Combine" and see the suggestions it brings up and more importantly WHERE IN THE LIST it places the highlight. If you're fast on the keyboard and hit the TAB key without looking at the suggestion it gives, you will get "TextTable.Combine".
What is TextTable.Combine? That's not even a Power Query Function. It an erroneous amalgamation of the FISRT word I typed plus the full command that it chose.
Look at the screen shot below and note the SUGGESTED row it highlights (the one it will take if you simply hit <Tab>) as opposed to the one three rows below it THAT IS AN EXACT MATCH OF WHAT YOU ARE TYPING
Really? You can't match "Text.Combine" with "Text.Combine" ?
I see this as a BUG.
Did I answer your question? If so, mark my post as a solution. Also consider helping someone else in the forums!
edhans
You should put this in the issues forum where the product team will see it.
100% agreed, there are a number of issues with Intellisense in Power Query. 😐
MCSA: BI Reporting
edhans
MCSA: BI Reporting
Done:
https://community.powerbi.com/t5/Issues/Power-Query-Intellisense-not-working-well/idi-p/1275162
Thanks for the link.
