Don't miss your chance to take the Fabric Data Engineer (DP-600) exam for FREE! Find out how by attending the DP-600 session on April 23rd (pacific time), live or on-demand.
Learn moreNext up in the FabCon + SQLCon recap series: The roadmap for Microsoft SQL and Maximizing Developer experiences in Fabric. All sessions are available on-demand after the live show. Register now
Having an 'auto complete' feature in a coding language is great.
When it work right.
Power Query auto complete does NOT.
Try this: Open a query and click the Custom Column on the Add Column menu. The dialog box opens where you input your M language statement.
Now type into the formula box "Text.Combine" and see the suggestions it brings up and more importantly WHERE IN THE LIST it places the highlight. If you're fast on the keyboard and hit the TAB key without looking at the suggestion it gives, you will get "TextTable.Combine".
What is TextTable.Combine? That's not even a Power Query Function. It an erroneous amalgamation of the FISRT word I typed plus the full command that it chose.
Look at the screen shot below and note the SUGGESTED row it highlights (the one it will take if you simply hit <Tab>) as opposed to the one three rows below it THAT IS AN EXACT MATCH OF WHAT YOU ARE TYPING
Really? You can't match "Text.Combine" with "Text.Combine" ?
I see this as a BUG.
Proud to be a Super User! | |
You should put this in the issues forum where the product team will see it.
100% agreed, there are a number of issues with Intellisense in Power Query. 😐
MCSA: BI ReportingYou should put this in the issues forum where the product team will see it.
MCSA: BI ReportingDone:
https://community.powerbi.com/t5/Issues/Power-Query-Intellisense-not-working-well/idi-p/1275162
Thanks for the link.
| 6 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
