I need help with Power Query solution (code or transformation)
I need to create code or solution in Power Query becaus this will used in next ransformations. Any help is greately apreciated!
Where "WER" = Yes then Find value from ABC and Populate where EFG is the same.
ABCEFGWERVG (Leader)Solution (Group Leader)
qwewabNo xyzacd
wwdabNo xyzacd
sffdabNo xyzacd
afedfdgdgabNo xyzacd
xyzacdabYesxyzacdxyzacd
dfddfgabNo xyzacd
rfdsddssNo grftrt
jhjhdfjdssNo grftrt
grftrtssYesgrftrtgrftrt
sfdgfdgfdssNo grftrt
eewewxrgNo Null
dfsdfdrgNo null
fghsrrgNo Null
sdsdgffNo Null
dfdffffNo Null
jgeddes
Here is one possible solution to your question.
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("fZDRDsIgDEV/xfC8b9m7IXtAL2Uhi0Y6w/Tr7RCVJa4JNKTncEOx1tyyz6Yz7iSlv0o5yF4eT3eGGTprcoaGmUjljjwIAUGT6rEaR88/vPEkCaQmJQJjvcXcGiHRnOZixDGOoKg69ViN93u+vcZjmawsLcx7+eFFeim0Rn+fpjoUoyRs+eXDKYyc9q+zDLwSop10FPIPDy8=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ABC = _t, EFG = _t, WER = _t, #"VG (Leader)" = _t, #"Solution (Group Leader)" = _t]),
    #"Changed Type" =
    Table.TransformColumnTypes(
        Source,
        {{"ABC", type text}, {"EFG", type text}, {"WER", type text}, {"VG (Leader)", type text}, {"Solution (Group Leader)", type text}}
    #"Grouped Rows" =
    Table.Group(
        #"Changed Type",
        {"EFG"},
        {{"_nestedTable", each _, type table [ABC=nullable text, EFG=nullable text, WER=nullable text, #"VG (Leader)"=nullable text, #"Solution (Group Leader)"=nullable text]}}
    fxLeaderValue = (inputTable as table) =>
        rows = Table.SelectColumns(Table.SelectRows(inputTable, each [WER]= "Yes"), {"ABC"}),
        value = Table.AddColumn(inputTable, "Solution", each Table.FirstValue(rows))
        value,
    Custom1 =
    Table.TransformColumns(
        #"Grouped Rows",
            {"_nestedTable", each fxLeaderValue(_)}
    #"Expanded _nestedTable" =
    Table.ExpandTableColumn(
        Custom1,
        "_nestedTable",
        {"ABC", "WER", "VG (Leader)", "Solution"},
dufoq3
Hi @Anonymous, different approach.
Result
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("bZDBCsMgEER/pXjOt/ReJIe04yheSt2Aab++q0kLhgUZ8D3GXfTevWqobnLLXeP61Li4efKuVhhUSAsvDCAiouG292d5/Eu3IJoHa1p7oNUrhKD1REaRU05gtlQsXMv6E/usg+3bI/ZjVEPQf9j0WuIoQEFvnAVjkmJw0b0bIs8PoaOBz18=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ABC = _t, EFG = _t, WER = _t, #"VG (Leader)" = _t]),
    Ad_Solution = Table.AddColumn(Source, "Solution (Group Leader)", each if [WER] = "Yes" then [#"VG (Leader)"] else null, type text),
    GroupedRows = Table.Group(Ad_Solution, {"EFG"}, {{"All", each Table.FillUp(Table.FillDown(_, {"Solution (Group Leader)"}), {"Solution (Group Leader)"}), type table}}),
    CombinedAll
Thank you so much I will try that solution.
jgeddes
    #"Changed Type" =
        Source,
    #"Grouped Rows" =
    Table.Group(
        #"Changed Type",
        {"EFG"},
        value,
    Custom1 =
        #"Grouped Rows",
        Custom1,
        "_nestedTable",
July Power BI Update Carousel
