manisharora
How to connect Power BI with SAP ECC system
Hi Team,
I have requirement to pull data from SAP ECC system. Please guide me how i can integrate SAP ECC system with Power BI.
And if you have any document/URL where all connectivity steps is defined. please share with me.
Thanks in advance
Manish Arora | BI consultant
I was trying to connect to SAP ECC through power bi desktop, but i couldnt find the option to connect to sap ecc,
can any one tell me the steps on how to integrate to SAP ECC.
JuliaYebra
Helper III
Helper III
As long as I Know you can't get dat from SAP ECC.
You must have SAP HANA in order to get data from SAP or use the preview feature SAP Business Warehouse connector.
Thanks Julia..But we need to integrate with SAP-ECC..
Manish Arora
You can connect directly to SAP Database on SQL Server or Oracle, whatever, we used this with Qlikview and it also works good with Power BI, you just need to have a good knowledge about SAP Database structure
That would be perfect!
Did you have burocratic problems to get access to the database?
I imagine that in our company it would be a big challenge to convince security department because all the compliance restrictions, but others success experiencies will help us!!
